Sterelobs ZED Box 2
- SKU: MBS-ENTB-143
- Category: Development Boards
Manufacturers:
Sterelobs ZED Box 2
- Orin NX 8 GB or 16 GB
- M.2 NVMe SSD, 256 GB, 1 TB or 2 TB
- Ubuntu 24.04 (L4T)
The Stereolabs ZED Box 2 is a compact, industrial-grade edge AI computer for robotics, autonomous mobile robots and industrial automation. Based on the NVIDIA Jetson Orin NX Super, it delivers up to 157 TOPS of AI performance and processes data from up to eight cameras directly on the robot – without the cloud and without an additional PC.
Eight GMSL2 inputs (FAKRA-Z) enable hardware-synchronized multi-camera setups with Stereolabs ZED X and ZED X One, including mixed stereo and mono configurations. Via Ethernet, USB 3.2, CAN and digital I/Os, additional sensors such as LiDAR, GPS or IMU can be integrated and fused.
The passively cooled aluminum enclosure operates fanless with no moving parts, provides ESD protection and a wide 10–32 V input range. With JetPack and the ZED SDK preinstalled, the ZED Box 2 is ready to use out of the box.
Ideal for:
- Autonomous mobile robots (AMRs) and logistics robots
- 360° perception with multiple stereo and mono cameras
- Inspection, monitoring and industrial machine vision
- Sensor fusion of camera, LiDAR, GPS and IMU
- AI inference at the edge, e.g. object detection and tracking with custom models
Key Benefits
- NVIDIA Jetson Orin NX Super with up to 157 TOPS of AI performance
- 8 × GMSL2 for hardware-synchronized multi-camera systems
- Up to 8 ZED X stereo cameras at HD1200 and 30 fps
- Fanless aluminum enclosure, optional fan kit for sustained workloads
- Wide 10–32 V DC input range, ESD protection
- Industrial interfaces: 2 × GbE, 2 × CAN, sync/I/O connector
- Wall and DIN-rail mounting
- JetPack and ZED SDK preinstalled, custom AI models via TensorRT, CUDA or PyTorch
The ideal choice for anyone who wants to run multi-camera perception and AI directly on their robot or machine.
Variants Compared
| Parameter | Orin NX 8 GB Super | Orin NX 16 GB Super |
| AI performance | up to 117 TOPS | up to 157 TOPS |
| CPU | 6-core Arm Cortex-A78AE, 2 GHz | 8-core Arm Cortex-A78AE, 2 GHz |
| DL accelerator | 1 × NVDLA v2 | 2 × NVDLA v2 |
| Memory | 8 GB LPDDR5 | 16 GB LPDDR5 |
| GPU, interfaces, enclosure | identical | |
Technical Specifications
| Computing | |
| Module | NVIDIA Jetson Orin NX 8 GB or 16 GB Super |
| GPU | 1024-core NVIDIA Ampere with 32 Tensor Cores |
| Storage | M.2 NVMe SSD, 256 GB, 1 TB or 2 TB |
| Video | Hardware encoding/decoding AV1, H.265, H.264 |
| Cameras | |
| Camera inputs | 8 × GMSL2 (FAKRA-Z), hardware-synchronized |
| Compatible cameras | ZED X (stereo), ZED X One (mono), also mixed |
| Stereo | up to 8 × HD1200 @ 30 fps or 4 × HD1200 @ 60 fps |
| Mono | up to 8 × HD1200 @ 60 fps or 6 × 4K @ 15 fps |
| Interfaces | |
| Ethernet | 2 × Gigabit Ethernet |
| USB | 3 × USB 3.2 Gen 2 Type-A, 1 × micro USB 2.0 (flashing/OTG) |
| CAN | 2 × CAN (DB9) |
| I/O | Sync/I/O connector (DB9), 1 × configurable digital I/O |
| Display | 1 × HDMI 2.1 |
| Wireless | Wi-Fi 6 |
| Mechanical and Environmental | |
| Power supply | 10–32 V DC, max. 80 W |
| Cooling | Passive (fanless), optional fan kit |
| Dimensions (L × W × H) | 234.4 × 176.3 × 54.0 mm |
| Weight | approx. 2.3 kg (with fan) |
| Operating temperature | -20 °C to +50 °C (storage -40 °C to +85 °C) |
| Mounting | Wall mount (brackets included), DIN rail |
| Certifications | CE, FCC, EMC, RoHS, REACH, IEC 62368-1 |
| Software | |
| Operating system | Ubuntu 24.04 (L4T) |
| Preinstalled | NVIDIA JetPack, Stereolabs ZED SDK |
| AI frameworks | TensorRT, CUDA, PyTorch; custom detectors (e.g. YOLO as ONNX) in the ZED SDK |
| Item information | Value |
| Shipping weight: | 2,70 kg |
| Item weight: | 2,30 kg |
