Stereolabs ZED Box 2 Max - T5000
- SKU: MBS-ENTB-145
- Category: Development Boards
Manufacturers:
- up to 2,070 FP4 TFLOPS
- 128 GB LPDDR5X with 273 GB/s memory bandwidth
- GPU: 2,560-core NVIDIA Blackwell, 5th-generation Tensor Cores, MIG
The Stereolabs ZED Box 2 Max – T5000 is the flagship of the ZED Box 2 series: an industrial physical AI computer for humanoids and advanced autonomous machines. With the NVIDIA Jetson AGX Thor T5000, 128 GB of LPDDR5X memory and up to 2,070 FP4 TFLOPS, it runs multi-camera perception, sensor fusion and large AI models such as vision-language-action (VLA) models simultaneously, directly on the robot.
Eight GMSL2 inputs (FAKRA-Z) capture up to eight ZED X stereo or mono cameras on a shared hardware clock. For LiDAR, network cameras and other sensors, it offers a QSFP+ port with 4 × 10 GbE, two Gigabit ports, Wi-Fi 6, four CAN FD buses and optionally four PoE+ ports. The ZED Box 2 Max is also optionally available with an integrated RTK-capable GNSS receiver.
The actively cooled aluminum enclosure is built for industrial use – with a wide 9–36 V input range, an additional USB-C PD input and protection against transients, reverse polarity and ESD. The ZED SDK comes preinstalled, and ROS 2 and Isaac ROS are supported.
Ideal for:
- Humanoid robots and mobile manipulators
- Running large AI models (VLA, LLM) alongside perception
- 360° perception with up to eight synchronized cameras
- Fusion of camera, LiDAR and GNSS in autonomous machines
- Outdoor robotics with precise RTK positioning (GNSS variant)
Key Benefits
- NVIDIA Jetson AGX Thor T5000 with up to 2,070 FP4 TFLOPS
- 8 × GMSL2 for hardware-synchronized multi-camera systems
- QSFP+ with 4 × 10 GbE, 2 × GbE, optional 4 × PoE+
- 4 × CAN FD for direct connection to vehicle and drive systems
- Optional RTK GNSS (L1/L2/L5) and slots for 4G/5G
- Wide 9–36 V input range and USB-C PD, with reverse polarity and ESD protection
- ZED SDK preinstalled, support for ROS 2 and Isaac ROS
- Power supply, GMSL2 cables and antennas included
The ideal choice for anyone who needs maximum AI performance for perception, sensor fusion and large models on a single platform directly on the robot.
Technical Data
| Computing | |
| Module | NVIDIA Jetson AGX Thor T5000 |
| AI performance | up to 2,070 FP4 TFLOPS |
| GPU | 2560-core NVIDIA Blackwell, 5th-gen Tensor Cores, MIG |
| CPU | 14-core Arm Neoverse-V3AE, 2.6 GHz |
| Memory | 128 GB LPDDR5X, 256-bit, 273 GB/s |
| Storage | NVMe SSD, 256 GB, 1 TB or 2 TB |
| Video | Encoding e.g. 6 × 4Kp60 H.265, decoding e.g. 4 × 8Kp30 H.265 |
| Cameras | |
| Camera inputs | 8 × GMSL2 (FAKRA-Z), hardware-synchronized |
| Compatible cameras | ZED X stereo and mono cameras (configuration depends on resolution, frame rate and bandwidth) |
| Networking and Communication | |
| Ethernet | 1 × QSFP+ (4 × 10 GbE), 2 × GbE RJ-45 |
| PoE+ (optional) | 4 × GbE PoE+, 25 W per port |
| Wireless | Wi-Fi 6 (2.4/5 GHz) |
| Cellular | 2 × SIM slot for optional 4G/5G module (not included) |
| GNSS (optional) | Dual-band L1/L2/L5, RTK-capable |
| Interfaces | |
| CAN | 4 × CAN FD |
| USB | 4 × USB 3.2 Type-A (2 × 5 Gbps, 2 × 10 Gbps), USB 3.2 Type-C |
| I/O | 4 × PWM |
| Display | 2 × HDMI 2.0 (3840 × 2160 @ 60 Hz) |
| Audio | 2 × 3.5 mm jack (mic in, line out) |
| Mechanical and Environmental | |
| Power supply | 9–36 V DC (terminal block, max. 10 A) or USB-C PD (9–28 V, 40–130 W); max. 250 W |
| Protection | Transients, reverse polarity, ESD |
| Cooling | Active |
| Enclosure | Industrial aluminum enclosure, black |
| Dimensions (L × W × H) | 261.5 × 206.5 × 84.8 mm |
| Operating temperature | -25 °C to +50 °C (storage -40 °C to +85 °C) |
| Software | |
| Operating system | Ubuntu 24.04 (L4T) |
| Preinstalled | Stereolabs ZED SDK |
| Supported | ROS 2, NVIDIA Isaac ROS |
Scope of Delivery
- 1× Stereolabs ZED Box 2 Max – T5000 (with selected options)
- 1× power supply
- 2× GMSL2 cable 1-to-4
- 1× USB-C to USB cable
- 2× Wi-Fi antenna (2.4/5 GHz)
- 2× GNSS antenna L1/L2/L5 (GNSS variant only)
Cameras and 4G/5G module are not included.
| Item information | Value |
| Shipping weight: | 6,00 kg |
| Item weight: | 4,00 kg |
