Voyant Carbon Lidar
  • SKU: MBS-SES-401
  • Category: LiDAR
Voyant Carbon Lidar
  • 4D FMCW LIDAR sensor
  • High-precision 4D point clouds
  • Class 1 eye-safe
  • IP67
Voyant’s Carbon is the first 4D FMCW LiDAR sensor specifically designed for industrial applications. With a strong focus on cost efficiency, Carbon delivers high-performance 4D sensing even for the most cost-sensitive applications, breaking cost barriers and transforming the industry.
Carbon provides high-precision 4D point-cloud data at minimal cost, in a compact form factor, and with low power consumption. The sensor delivers instant measurements of velocity, range, and reflectivity without the typical issues of conventional LiDAR systems, thanks to its immunity to blooming, sunlight, and interference from other sensors.
Voyant’s Carbon leverages a unique FMCW technology that surpasses traditional LiDAR systems by delivering instant per-pixel velocity measurements in addition to accurate 3D positioning.
This exceptional performance combined with high affordability is the result of decades of research, culminating in the integration of all optical components and beam steering on a custom LiDAR photonic integrated circuit (PIC). As a result, vertical beam steering is fully solid-state, enabling unprecedented improvements in size and robustness.
Technical Data Carbon30
  • Field of View: 30° VFOV, 90° HFOV (software-defined 10°-90°)
  • Range on 10% target*: 70m
  • Max Range: 190m
  • Min Range: 0,1m
  • Nominal lines per frame: up to 128
  • Range precision: 3mm in some operating modes; 2,5cm General operation
  • Range Accuracy: 0,1% of measured range
  • Maximum Detectable Radial Velocity: 63m/s
  • Radial Velocity Precision: 2,8cm/s
  • Detection Rate: 488,000 PPS, up to 976,000 PPS in fast capture mode
  • Angular Resolution: 0.24° elevation (vertical) point spacing (128 Pixels); 0,12° azimuth resolution
  • Frame Rate: 10fps (software-defined 0-20fps)
  • Operating Temperature: -20° to +65°C
  • Storage Temperature: -40° to +85°C
  • Sealing: IP67
  • Power Consumption: <35W
  • Dimensions: 110 x 60 x 60 mm
  • Weight: <300 g
  • Eye safety: Class 1 eye-safe per IEC 60825-1:2014
  • Shock: 50 G / 11 ms half-sine, 6 directions
  • Vibration: 2.0 G rms random vibration
  • Synchronization: 802.1AS gPTP
  • Data Output: Gigabit Ethernet (1000BASE-T), providing(X, Y, Z) or (azimuth, elevation, range) (single return); Radial velocity; Calibrated reflectivity
  • Interface: M12 X-code, PoE++ (802.3bt)
  • Software: C/Python/ROS/ROS2 APIs available including super resolution and 6DOF motion estimation.
Technical Data Carbon60
  • Field of View: 60° VFOV, 60° HFOV (software-defined 10°-60°)
  • Range on 10% target*: 30m
  • Max Range: 75m
  • Min Range: 0,1m
  • Angular Resolution: 0.47° elevation (vertical) point spacing (128 Pixels); 0,12° azimuth resolution
  • Sealing: IP67
  • Weight: <300 g
Shipping weight: 0,80 kg
Item weight: 0,30 kg
Price on request
