Arducam 12MP*2 Synchronized Stereo Kit for NVIDIA® Jetson
  • SKU: MBS-SES-348
  • GTIN: 0658917513634
  • HAN: B0265N
  • Category: Sensors
Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit
  • for NVIDIA® Jetson Nano/Xavier NX/AGX Orin/Orin Nano/Orin NX
  • Two 12.3MP 477P Camera Modules
  • with CS Lens
  • Camarray Stereo Camera HAT
Arducam 12MP Stereo Camera Kit for Synchronized Applications
The Arducam 12MP Stereo Camera Kit allows the simultaneous operation of two high-resolution 12MP camera modules via a single MIPI CSI-2 port on Jetson Nano and Jetson Xavier NX platforms. This kit includes two high-quality 12MP camera modules and an Arducam Stereo Camera HAT. The HAT uses ArduChip technology to merge the connection of both cameras into one, enabling seamless recognition by single-board computers. This kit is ideal for building a stereo camera system for depth sensing applications or upgrading an existing IMX219 stereo setup.
Kernel Driver Usage
  • This system requires kernel drivers to operate; each kernel version needs a specific driver.
  • Not compatible with versions earlier than JetPack 4.3 (L4T 32.3.1).
  • Updating or downgrading the operating system may require reinstalling a compatible driver.
  • Future JetPack or kernel updates will require new drivers. In case of delays in their availability, please kindly notify us.
Applications:
  • Robot navigation
  • Object tracking
  • 3D measurements
  • 3D reconstructions
  • Vision applications with depth sensing
Key Features:
  • Compatibility: Natively supports Jetson Nano, Xavier NX, Orin Nano, and Orin NX. Note: Not compatible with Raspberry Pi. For Raspberry Pi, refer to version B0265R.
  • High Resolution: Includes two cameras with 1/2.3" 12.3-megapixel sensors delivering sharp images at a maximum resolution of 4056(H) x 3040(V). The cameras come equipped with CS-Mount lenses featuring a 6mm focal length, a manual focus ring, and adjustable aperture.
  • Hardware Synchronization: Images from both cameras are synchronized at the hardware level, eliminating the need for additional methods such as timestamp synchronization.
  • Adjustable Baseline: Unlike fixed stereo camera modules, this kit offers greater flexibility and can be used with an adjustable baseline device controlled by computer systems. This allows quick and dynamic adjustments to achieve stereoscopic binocular vision with human-like degrees of freedom.
Image Sensor
  • Image SensorIMX477P
  • Still Resolution12.3 Megapixels
  • Color Filter TypeColor
  • Shutter TypeRolling Shutter
  • Optical Size1/2.3"
  • Pixel Size1.55 µm x 1.55 µm
  • Sensor Active Area4056(H)×3040(V)
  • Output FormatRAW8/RAW10/RAW12
  • Video Modes (on NVIDIA Jetson)L4t 32.x: 4056x3040@10fps, 2028x1529@40fps, 2028x1080@50fps
  • L4t 35.x: 4056×3040@10fps, 2028×1520@30fps, 2028×1080@30fps
  • IR SensitivityIntegral IR-cut Filter, visible light only
Lens
  • Focus TypeManual
  • Focal Length6mm
  • F.NOF1.2
  • Field of View (FOV)65°(H)
  • Lens MountCS-mount
  • MOD0.2m
Electrical and Mechanical
  • Working CurrentMax 380 mA
  • Camera Board Size38 ×38 mm
  • Camarray Hat Size65×56 mm
Functionality and Compatibility
  • ISP SupportNot Supported
  • External TriggerNot Supported
  • Aggregate modeHalf Spelling Combine
Lens Options
CS-Mount Lens
SKU
LN051
LN050
LN038
LN039
LN040
LN041
LN029
Part No
CS17320M12
CS2316ZM02
CS2308ZM05
CS2008ZM05A
CS1812ZM03
CS2325ZM01
CS1806ZM06
Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
MOD 0.3m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
Size(mm)
28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
NOTE: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
C-Mount Lens
SKU
LN057
LN054
LN052
LN049
LN048
LN046
LN042
LN043 LN044 LN045 LN047
Part No
C2308ZM50
C1550ZM01
C1535ZM02
C20280M12
C2004ZM12
C1016ZM02
C1705ZM07
C1508ZM04
C1512ZM03
C1516ZM02
C1535ZM01
Optical Format 1/2.3″ 2/3″  2/3″ 1/2" 1/2" 1'' 1/1.7" 2/3" 2/3" 2/3"  2/3"
EFL(mm) 8-50 50.00 35.00 2.8-12 4-12 16.00 5.00 8.00 12.00 16.00 35.00
BFL(mm) 17.53 17.53 17.53 17.53 17.53 17.53 17.53 17.53 17.53 17.53 17.53
F/NO 1.4 1.8-16 1.6-16 1-1.6 1-1.6 1.4-1.6 1.6-16 1.6-16 1.6-16 1.6-16 1.7-16
HFOV on 1/2.3‘’ Cam 45°-5.35° 7° 18° 120°-38° 80°-32° 24° 65° 44° 31° 24° 10°
MOD 0.2m 0.50m  0.30m 0.30m 0.20m 0.20m 0.15m 0.15m 0.20m 0.20m 0.20m
Size(mm)
40 x 68.3 34×40.5 50×35.5 44.5×58.5 33×43 39×50 39×41.5 39×41 34×41.5 33×36.5 35×30
NOTE : For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses in bulk.
  • 2 pcs 12.3MP color camera module mounted with CS lens
  • 1 pcs Arducam Camarray Stereo Camera HAT
  • 2 pcs 150mm/6inch 22pin to 22pin camera cables
  • 1 pcs 300mm/12inch 15pin to 22pin camera cable
  • 1 pcs 300mm/12inch 22pin to 22pin camera cable
  • 2 pcs M2.5*10mm Nylon Hex Standoffs
  • 2 pcs M2.5*6mm Nylon Screws
€ 269,95
