NVIDIA Jetson Orin NX Industrial PC without fanless - DSBOX - ORNX
  • Supercomputing Performance
  • Multi-Stream Deep Learning Edge analytics
  • 1024-core-GPU
  • Ampere Architecture with 32 Tensor Cores
  • up to 18 Videoströme in 1080p @30 FPS
This fanless PC from NVIDIA offers limitless AI performance and is suitable for industrial applications with dual LAN connectivity. Complex industrial applications can be handled thanks to the NVIDIA Jetson Orin NX with 1024-core GPU and NVIDIA Ampere architecture with 32 tensor cores. Added to this is the Edge AI implementation system, which enables multi-stream video processing applications. It is capable of decoding 18 video streams in 1080p at 30fps and delivers AI performance of up to 100 TOPS due to the 1024 NVIDIA CUDA cores, 32 Tensor cores, up to 8-core ARM 64-bit CPU and up to two NVIDIA Deep Learning Accelerators (NVDLA) engines. Using the NVIDIA Deep Stream SDK, maximum performance is evoked for concurrent video processing applications: up to 271fps for Resnet-34-based person recognition and up to 34fps for Resnet-34-based location algorithms.
The PC offers multiple Gigabit Ethernet ports, USB 3.1 Type-C ports, and a CAN-BUS interface. in addition to RS232 and RS422 ports, digital input and output ports, and JetPack 5.1 support, which is required to support the Orin NX 8GB, for NVIDIA Jetson devices. WiFi/Bluetooth is also supported via expansion jacks and 2x M.2 Key-M SSD slots, as well as 1x M.2 Key-E slot. Easy display connectivity with the maximum resolution of 3840x2160 is enabled via HDMI 2.0 port.
The form factor and ruggedness make it ideal for industrial applications, with the wide temperature range also contributing. This fanless PC has a wide input voltage range of 9-28 VDC and offers a robust power supply design. The intelligent power management system automatically adjusts power consumption to system requirements and has an emergency power system, so important data is preserved.
  • Supported modules: NVIDIA Jetson Orin NX 8GB / 16GB
  • Memory: 8GB 256-bit LPDDR5 / 16GB 128-bit LPDDR5
  • Graphics interfaces: 1x HDMI 2.0 (max. Resolution 3840x2160)
  • Interfaces: 2x Gigabit Ethernet, 3x USB 3.1 Type-C, 1x CAN Bus, 1x RS232 & 1x RS422, 1x Micro USB 2.0 (recovery), 2x digital Input, 2x digital output
  • Wireless communication: WiFi/Bluetooth connectivity by Extension sockets
  • Power supply: 9-28 VDC
  • Extension sockets: 1x M.2 Key-E, 1x M.2 Key-B, 1x SIM
  • Mass Storage: 2x M.2 Key-M SSD slot
  • Ambient conditions: -25° C ~ 85°C
  • Dimension: 110 x 130 x 60 mm
  • Weight: 765g
  • JetPack support: JetPack 5.1
  • NVIDIA Jetson Orin NX Industrial Fanless PC with Dual LAN
Shipping weight: 1,00 kg
Item weight: 0,76 kg
Datasheet DSBOX-ORNX-LAN
SSD
Processor
Power-Brick
from
€ 1.270,95
