Clearpath Robotics Husky A300 High Power Charger
  • SKU: MBS-Z-331
  • GTIN: 0658917513436
  • Category: Accessories
  • 650 watt battery charger
  • Specifically designed for the Husky A300 Unmanned Ground Vehicle (UGV) e
  • based on the Delta-Q IC650 model
  • Provides a fast, reliable and weatherproof charging option
The Clearpath Robotics Husky A300 High Power Charger is a powerful 650-watt battery charger specifically designed for the Husky A300 Unmanned Ground Vehicle (UGV). Based on the Delta-Q IC650 model, it provides a fast, reliable, and weather-resistant charging solution for the Husky A300. The High Power Charger is ideal for applications requiring rapid charging and durability, making it well-suited for research and development projects, industrial automation, and service robotics.
  • Model: Delta-Q IC650 (650 W)
  • Output Voltage: 27.7 V DC
  • Output Current: approx. 23.5 A
  • Enclosure Protection: IP66 (suitable for outdoor use)
  • Operating Environment: Indoor and outdoor (with limitations: AC power cable must be protected outdoors)
  • Charging Time (Husky A300 with 40 Ah battery): approx. 1 hour 45 minutes
  • Charging Time (Husky A300 with 80 Ah battery): approx. 3 hours 30 minutes
  • Charging Time (Husky A300 with 120 Ah battery): approx. 5 hours 15 minutes
  • Communication Interface: USB 2.0
  • Operating Temperature Range: –20 °C to +60 °C
  • Special Features: Supports larger Husky A300 battery options (e.g., upgrade or extended batteries)
Features and Benefits
  • Fast Charging: High power output significantly reduces charging time compared to the standard charger.
  • Weather-Resistant: With IP66 protection, the charger is suitable for outdoor use.
  • Compatibility: Supports various Husky A300 battery options, including larger capacity batteries.
  • Easy Integration: The communication interface allows simple integration into existing systems.
Operating Notes
  • Power Cable: When used outdoors, the AC cable should be protected from rain or moisture (e.g., under a cover).
  • Charging Environment: For indoor use, choose a dry and well-ventilated area.
  • Maintenance: Regularly inspect the charger for visible damage or wear.
€ 2.819,95
Docs MYBOTSHOP documentation
