ROBOTIS LIPO Battery Charger LBC-010
  • SKU: MBS-Z-38
  • GTIN: 8809052930028
  • HAN: 903-0144-000
  • Category: Accesoires
ROBOTIS LiPo Battery Charger LBC-010
  • Supports charging S2 and S3 cells ( not at the same time )
  • Compatible with LiPo 11.1V, battery set: LB-010, LB-011, LB-012
  • Input voltage: 10~18V
  • output current: 1.1A
This charger is designed for a LiPo.battery and supports charging 2S and 3S cells, but the exception exists that they cannot be charged simultaneously. If the SMPS is used for the current, it must be accompanied with the SMPS 12V 5A.
  • Output voltage: 2S cell: 8.4V | 3S cell: 12.6V
  • Output current: 1.1A
  • Status
    • Red LED: Charging
    • Green LED: charging completed
    • Flashing red LED: bad battery Connection.
  • Compatible with: LiPo 11.1V battery pack LB-010, LB-011, LB-012.
Attention
  • Do not apply heat, water or liquids to the battery.
  • Do not disassemble the battery
  • Do not use damaged batteries
  • 2S and S3 cells must not be charged at the same time
  • The poles must be connected correctly when charging
  • Do not charge when the battery is hot
  • Do not charge when the battery is being used by the controller
  • Do not connect when the battery is fully charged
  • ROBOTIS LiPo Battery Charger LBC-010
Shipping weight: 0,05 kg
Item weight: 0,05 kg
€ 17,95
