ROBOTIS OP / TB3 LIPO Battery 11.1V 1800mAh LB-012
  • SKU: MBS-Z-43
  • GTIN: 0880952932404
  • HAN: 903-0210-000
  • Category: Accesoires
ROBOTIS LB-012
Rechargeable Lithium Polymer (Lipo) battery designed for ROBOTIS DARwin OP, OP2, OP3 and Turtlebot3. The right way of loading is attached to the kit that are mentioned above.
  • compatible: DARwin OP, OP2, OP3 & TB3
  • Weight: 106g
  • Dimensions: 88 x 35 x 26mm
  • Voltage: 11,1V
  • Capacity: 1800mAh
  • Discharge rate: 5C
  • ROBOTIS LB-012  Lipo battery
Shipping weight: 0,14 kg
Item weight: 0,14 kg
€ 74,95
