Sabertooth Dual 2x60A/6-30V Motor Driver
- SKU: MBS-M-07
- GTIN: 0096718605170
- HAN: US
- Category: Motordriver
Manufacturers:
- 2x60A Power | 120A Peak
- 6-30V Voltage
- PWM & TTL Serial
- Overcurrent protection
- 5V / 1A BEC
General
The Sabertooth 2x60A Dual Motorcontrollerboard is an very efficient driver module wich can be used in multiple ways espacially for robots based on wheels or chains up to 80kg. The Motorcontrollerboard is designed for a power consumption of 60A per DC-motor with a maximum power consumption of 120A. The Sabertooth Controller can also supply external user with 5V and a maximum of 1A due to the integrated BEC module. This means that a second voltage supply for a possible additional periphery is not needed.
Beneftis & External Encoder - Module
The Sabertooth 2x60A Dual Motorcontrollerboard is provided with an overcurrent- & overtemperature protection wich automatically puts the Sabertooth controller into safety mode when exposed to high currents. In addition to that the transistors are clocked with 32KHZ wich results in a very silent Operation.
The Sabertooth Controller can furthermore be enhanced with a Motion Controller (Kangaroo x2) to higher the positioning accuracy even more. the Motion Controller, wich can also hold an Quadrat-Encoder or Potentiometer, only has to be plugged onto the controllerboard.
Controlling
Due to the microcontroller supported controlling the Sabertooth Dual 60A Regenerative Motorcontrollerboard can be controlled via PWM signals or with a serial / TTL interface. Both the PWM signal and the interface can be found in every common singel-board computers and Atmel & ST uC's.
The selection of the kind of signal, the adjustment of the adress and baudrate can be done with the switches that can be seen below. The full documentation regarding the configuration can be found in the data sheet.
The full data sheet can be found HERE.
- 60A continous, 120A peak per channel
- Recommended 6V-30V
- Synchronous regenerative drive
- Ultra-sonic switching frequency
- Thermal and overcurrent protection
- Lithium protection mode
- Controlling via PWM Signals & TTL
Documentation
Software
| Item information | Value |
| Shipping weight: | 0,30 kg |
| Item weight: | 0,24 kg |
All reviews:
- Available immediately
Delivery time: 1 - 3 Workdays (DE - int. shipments may differ)
