SmartAP AIRLink 4G Enterprise Set
SmartAP AIRLink Set
  • fast and easy integration and camera mounting
  • FPV and payload camera inputs
  • all interfaces are open on all sides
  • incl. HD FPV camera
  • 1080p HDR camera
  • UTM integrated and BVLOS ready
AIRLink stands for Artificial Intelligence & Remote Link.
The AIRLink is equipped with a1080p HDR camera, which is capable of delivering excellent image quality. The FPV camera connector sits on the front, allowing for quick and easy integration and camera mounting, even in UAV designs. The native CSI interface provides the lowest possible latency (usually less than one frame, equal to 17 MS).
Advantages
  • all interfaces are open to all sides
  • FPV and payload camera inputs (incl. HD FPV camera)
  • 3-fold redundant, temperature stabilized and vibration damped IMU
  • Internet connectivity right out of the box: Ethernet, WiFi, LTE 4G/5G
  • UTM integrated and BVLOS Ready
Interfaces
  • Current input with voltage and current Monitoring
  • AI mission computer micro SD Card
  • Micro SD card for flight Control
  • AI mission computer USB Type-C
  • PPM input, SBUS output, RSSI monitor
Direct HDR FPV Camera Port:
  • Main connector for GNSS and Compass
  • Main connector for telemetry
  • CSI camera input
  • CAN 1 and 2
Internet connection:
  • SBUS Input
  • 16 PWM output channels
  • 2x LTE antenna jacks (MIMO)
  • WiFi antenna jack (AP and station modes)
  • 1 x AIRLink Enterprise unit
  • 1 x FPV camera with CSI cable
  • 1 x WiFi antenna with MMCX connector
  • 2 x LTE antenna with MMCX connector
  • 1 x HDMI to mini-HDMI cable
  • 1 x cable set (7 cables for all connections)
  • 1 x JST-GH to Ethernet RJ45 dongle
SmartAP Airlink Datasheet
€ 5.499,00
