Ark-Flow
  • SKU: MBS-DR-41
  • GTIN: 0658917512026
  • HAN: ARK-Flow
Open Source Dronecan Optical Flow and Distance Sensor Module
  • Enables unmanned aerial vehicles to fly in GPS denied environments such as inside buildings, tunnels, etc
  • Open Source Schematic, BOM, STEP Models
  • PixArt PAW3902 Optical Flow Sensor, Broadcom AFBR-S50LV85D Time-of-Flight Distance Sensor, Invensense ICM-42688-P 6-Axis IMU
  • ROS2 Support
The ARK-Flow is a highly advanced optical flow and distance sensor, specifically designed for use in GPS-denied environments. Whether in buildings, tunnels, or other indoor spaces, the ARK-Flow enables unmanned aerial vehicles (UAVs) to fly precisely and stably. The module combines cutting-edge sensor technology with open-source flexibility and offers extensive support for ROS2 and UAVCAN. Developed and manufactured in the USA, the ARK-Flow meets the highest quality standards and is FCC compliant.
Specifications:
  • Dronecan Optical Flow and Distance Sensor Module:
    • Next generation of PX4FLOW
    • Open-source schematic, BOM, and STEP models
    • Runs on PX4 open-source firmware
    • Supports UAVCAN firmware updates
    • ROS2 support
  • Sensors:
    • PixArt PAW3902 Optical Flow Sensor:
      • Operates in extremely low light conditions of >9 lux
      • Wide operating range from 80mm to infinity
      • Up to 7.4 rad/s
      • 40mW IR LED integrated for improved low light performance
    • Broadcom AFBR-S50LV85D Time-of-Flight Distance Sensor:
      • Integrated 850 nm laser light source
      • Field of view (FoV) of 12.4° x 6.2° with 32 pixels
      • Typical distance range up to 30m
      • Operates up to 200k Lux ambient light
      • Works well on all surface conditions
      • Transmitter beam of 2° x 2° to illuminate 1 to 3 pixels
    • Invensense ICM-42688-P 6-Axis IMU
  • STM32F412CEU6 MCU
  • Two Pixhawk Standard CAN Connectors:
    • 4 Pin JST GH
  • Pixhawk Standard Debug Connector:
    • 6 Pin JST SH
  • Compact Form Factor:
    • 3cm x 3cm x 1.4cm
  • LED Indicators
  • Made in the USA
  • FCC compliant
  • Power Requirements:
    • 5V
      • 71mA average
      • 76mA maximum
Package Contents:
Item weight: 0,01 kg
€ 326,95
