LIPSedge M3 LED Embedded 3D ToF Camera
LIPSedge™ M3 LED - 3D Modular Camera
  • Miniature design with precise position and location accuracy.
  • All-purpose ToF (Time-of-Flight) camera with USB Plug & Play compatibility.
  • Supports mid-range detection (20cm to 4 meters) with high-accuracy ToF technology.
  • Built-in 6-axis IMU for precise movement and position tracking.
  • Developer-friendly with cross-platform support for Windows, Linux, and Raspberry Pi, including SDKs for ROS, OpenCV, and more.
The LIPSedge™ M3 LED is an innovative, modular 3D camera specifically designed for embedded systems. Equipped with an integrated Inertial Measurement Unit (IMU), it provides precise position and motion data, enabling applications in interactive environments. This camera is suitable for various applications, including gesture control, people counting, behavior analysis, digital signage, and elevator capacity measurement.
This compact module features advanced Time-of-Flight (ToF) technology, making it easy to integrate into applications requiring a space-saving solution. The LIPSedge™ M3 LED supports a detection range from 20 cm to 4 meters, allowing precise distance measurement using ToF technology. The camera illuminates the scene with a modulated light source and measures the phase of the reflected light to calculate the object's distance.
With its integrated 6-axis IMU, the LIPSedge™ M3 LED delivers high precision in capturing movement and position data. It is resistant to ambient light, making it ideal for use in a wide range of lighting conditions. The camera is compatible across multiple platforms and supports operating systems such as Windows, Linux, and Raspberry Pi. Developers benefit from easy integration into existing systems with support for common SDKs, including ROS, OpenCV, and many other industrial 3D frameworks.
Point Cloud
LIPSense 3D Motion Gesture
Technical Specifications
  • Depth Technology: Time-of-Flight
  • Frame Rate: 80 x 60 @ 30fps (native)
  • Z-Accuracy: ≤3% typical (accuracy varies with distance)
  • Field of View (H x V x D): 74.1° x 57.5° x 92°
  • Aperture: f/1.2
  • Operating Range: Close mode: 0.2 ~ 1.0 m, Normal mode: 1 ~ 4 m
  • 6-Axis Sensor: 3-axis accelerometer & 3-axis gyroscope
  • Illumination Type: LED x 2 at 850nm wavelength
  • Dimensions: 51 x 28 x 22.4 mm
  • Interface: USB 2.0 Micro-B
  • Power Consumption: 4W
  • Operating Temperature: 0 ~ 40˚C
  • Storage Temperature: -20˚ ~ 60˚C
  • Supported SDKs: OpenNI 1.5 / 2.2, OpenCV
  • Supported Operating Systems: Windows 10, Ubuntu 16.04 / 18.04 LTS
  • Programming Languages: C / C++
  • Environment: Indoor
Package Contents
  • 1x LIPSedge™ M3 LED - 3D Modular Camera
Others (1)
Download Center
€ 279,99
