TeraRanger Evo Mini USB 2.0
  • SKU: MBS-SES-100-02
  • GTIN: 0618455051876
  • HAN: TR-EVO-MINI-USB
  • Category: Sensors
TeraBee TeraRanger Evo Mini USB 2.0
  • Single & Multi-Point LiDAR
  • 1,2 or 4 pixels
  • Measuring range: 0.03 - 3.3m
  • Connectivity: 2.0 USB
  • accuracy: 1cm
  • Compatibility: ROS & Pixhawk
The TeraRanger product series from the French company TeraBee comprises a wide range of LED LiDAR systems with different specifications and application possibilities. Nevertheless, these sensor modules are convincing due to their modular design, identical dimensions and interfaces to third-party software such as Pixhawk and ROS, and their amazing weight of only 9 grams. The TeraRanger EVO 6 Mini describes a 1.2 & 4 pixel LiDAR with a sensational update rate of up to 40Hz.
Application possibilities
The TeraBee products can be integrated into own applications as well as existing frameworks in the same comfortable way. Ready-to-use libraries/nodes are available for Pixhawk flight controllers as well as the very popular ROS middleware.
  • 1,2 & 4 Pixel Mode
  • Update rate: Up to 40Hz
  • Power: 5V / 0.05mA
  • Interface: 2.0 USB
  • Dimensions: 42 x 30 x 13mm
  • Weight: 9g
  • TeraBee TeraRanger EVO Mini USB
Shipping weight: 0,03 kg
Item weight: 0,03 kg
PDF (2)
Terabee Evo Mini Datasheet
Terabee Evo Mini User Manual
Interface
€ 64,95
