Hypersen 3D Solid-state LiDAR | HPS-3D160 Pro
Hypersen HPS-3D160 Pro
  • Wave length: 850 nm
  • Emitting angle: 76 °(Horizontal)x 32 °(Vertical)
  • Precision: ± 2cm
  • Measuring range:
    • 0.25~3m @10% reflectivity
    • 0.25~8m @90% reflectivity
The powerful 3D-Solid-State-LiDAR
The HPS-3D160 is a new generation of powerful 3D solid-state LiDAR sensors based on the time-of-flight principle. At a distance of up to 12 m, a reflection of 90% on a white target can be measured by an optimized illumination system and a low-distortion optical infrared lens. Due to flexible adjustment of the selected area (ROI) and Simple-HDR, Auto-HDR and Super-HDR modes, HPS-3D160 is widely used in all kinds of reflection scenes.
HPS-3D160 integrates a powerful 850nm infrared VCSEL transmitter, a high-sensitivity photosensitive element, a high-performance processor, and advanced data processing, filtering, and compensation algorithms. This combination can achieve extremely stable and synchronized measurement data output. With its rugged structure, industrial-grade IP67 waterproof design, and durable aerospace aluminum housing, the HPS-3D160 can be used in a variety of complex environments.
Technical Data
  • Model: HPS-3D160 Pro
  • Size: 78 x 40x 30(W*D*H) mm
  • Weigh: 110  g Power
  • supply: 12 ~ 24 V
  • Power consumption: 3 ~ 5 W
  • Strong light Performance: 80,000 Lux
  • Storage temperature: -40 ~ 85?
  • Operating temperature: -10 ~ 55?
  • Precision: ± 2cm
  • Measuring range:
  • Operating mode: Auto-HDR, Super-HDR),Simple-HDR Output data Depth data, average distance,signal strength, quantity of weak signal pixels, quantity of saturated pixels, maximum distance, minimum distance
  • Frame rate: 35Hz/adjustable
  • Power-on: initialization time 1500 ms
  • Communication interface: USB?RS232?USB-IO?LAN Optocoupler isolationI/O Standard: 1 input, 1 Output
  • Hypersen HPS-3D160 Pro
Shipping weight: 0,50 kg
Item weight: 0,44 kg
Interface
€ 523,95
  • Available immediately
